Trim stock transmission skid plate
Old Aug 28, 2011 | 01:41 PM
jeeeep's Avatar
Default Trim stock transmission skid plate
I'd like to see pics and what was used to trim the stock trans skid plate for front driveshaft.
I'd like to get the most use of what I have before spending more $$$ to buy more stuff... or better yet, sepnding those $$$ on other goodies!
Also trying to get the most life out of the stock driveshaft before switching it out.
Old Aug 28, 2011 | 03:14 PM
mkjeep's Avatar
Old Aug 28, 2011 | 03:19 PM
mkjeep's Avatar
Originally Posted by ludski
i heard about putting some washers in the bolts that hold on the tranny skid. to lower it down some.
i was planning on doing that, along with trimming the skid.
Old Aug 28, 2011 | 03:20 PM
jeeeep's Avatar
Originally Posted by mkjeep
Attachment 203674.............
did you cut with sawzall or grind down?
Old Aug 28, 2011 | 03:42 PM
mkjeep's Avatar
7 1/2in Craftsman grinder. That skid is Thick, cut-off tool went through a couple wheels pretty quick and i got impatient. So, I just ground it all down.
Old Aug 28, 2011 | 03:43 PM
mkjeep's Avatar
The washers between the skid and the frame is a TJ trick to lose driveline vibrations after a lift it's amazing how some of the knowledge transfers over, maybe it's because all of the owners transferred over.
Wife has an LJ
Old Aug 28, 2011 | 03:53 PM
jeeeep's Avatar
Grinder I have - thanks for the info and pics, just save me some $$$
Old Aug 28, 2011 | 04:03 PM
mkjeep's Avatar
Do take the skid off when you do this. I propped mine under a couple blocks of wood and stood on it. Let your grinder cool down for after grinding awhile or you'll burn it up.
