Rock Hard 4x4 rear bumper tire carrier
Old Aug 29, 2011 | 09:58 AM
cru9's Avatar
Default Rock Hard 4x4 rear bumper tire carrier
Looking for pics of rock hard 4x4 pics. Post up
Old Aug 29, 2011 | 04:19 PM
dadek's Avatar
Hope these help. I love mine and will be adding the fuel can carriers soon.
Old Aug 29, 2011 | 04:22 PM
matt852's Avatar
Sorry to hijack but do you have the full cage for the safari straps? Do you mind posting more pics of your safari straps/spiderwebshade combo?
BTW Super sweet set up all around.
Old Aug 29, 2011 | 04:24 PM
cru9's Avatar
Any rattling at all? Does your spare sit at a slight angle?
Old Aug 29, 2011 | 04:36 PM
sick jk's Avatar
Here ya go. No rattles. Rock solid. Huge carrier bearing. I live this bumper. And yes. The spare sits at a slight angle. It looks bad ass!
ID:	204077   Click image for larger version
Old Aug 29, 2011 | 05:00 PM
TieRod's Avatar
Mine rattled even after several adjustments. So I added a cam-type pull-down latch (not shown). Also the geometry of the spare carrier allows for a good bit of vibration side-to-side on washboards. I'll probably weld in a stiffener.
Otherwise I'm happy enuff. If I were buying right now there are better designs to be had.
Old Aug 29, 2011 | 05:04 PM
cru9's Avatar
Attachment 204095
DO you have a picture of your latch?
Old Aug 29, 2011 | 05:43 PM
TieRod's Avatar
Sorry no pics. My receipt is in AZ and I ordered it from an industrial hardware supplier. I'll keep on searching. It was rated at 1000 lb I believe.
Old Aug 29, 2011 | 06:45 PM
TieRod's Avatar
OK, finally. Similar to this. Mounted with handle down. Had to tweak the metal with grinder as the handle needed to rotate a bit more. Works great.
http://www.carrlane.com/catalog/inde...3C3B285351415F
Old Aug 29, 2011 | 07:39 PM
CALIJK's Avatar
I've got it and it has performed perfectly through some VERY hard wheeling. No rattling. Spare sits at an angle because it improves departure angle (a good thing):
