Rough country body lift?
Old Aug 29, 2011 | 03:17 PM
jeepsta's Avatar
Default Rough country body lift?
On all the other body lifts they supply new longer body mount bolts but on the rough country u just use the old ones wont they be to short since you are adding a 1.25 they supply the 2 bolts for each body mount but not the center with the washer..
Old Aug 29, 2011 | 03:27 PM
nthinuf's Avatar
Not an issue, everything you need is supplied in the kit. There is a link to the install guide on their website if you want to see the steps and pics.
Old Aug 29, 2011 | 03:37 PM
greenenvey's Avatar
im pretty sure im getting this body lift too!!
Old Aug 29, 2011 | 03:39 PM
jeepsta's Avatar
ok i just thought the center bolt would be to short adding 1.25 to meet the threads on the jeep again.
Old Aug 29, 2011 | 03:43 PM
jeepsta's Avatar
what holds the factory studs in just some kind of lock washer. No vice but do have hammer..
Old Aug 29, 2011 | 03:47 PM
jeepsta's Avatar
my kit arrives wednesday and my leveling kit and if u tell rough country u are a member of the forum they give u 10% off. teraflex leveling kit though.
Old Aug 29, 2011 | 03:49 PM
greenenvey's Avatar
good to know, this is the same setup im going with, i have the leveling kit installed already and am going to put the body lift on next!
Old Jan 14, 2012 | 05:12 PM
moorebi's Avatar
Default Factory bolts not long enough
I recently installed RC 1.25 body lift and all went well except when I went to install my rock rails and the center body bolt (3 on each side) are not long enough and they hit the bolts on the side of the body bolt.
Any idea where I can find longer body bolts and washers to make this work.
Thanks
Old Jul 25, 2012 | 06:57 AM
Ol' Bob's Avatar
Did you ever find longer bolts? If so where
