Superior Evo Shafts
Old Aug 29, 2011 | 06:12 PM
MikeyB's Avatar
Default Superior Evo Shafts
So I bent the flange on my stock rear shafts
Got Superior Evos and the same thing happened to the passenger side causing the brakes to squeak. I have wheeled it 2 times since and no hard drops or reasons for it to bend any. Anyone else have experience with this or with their warranty. I kept my stockers to use if I have to send them back.
Kind of bummed they did not last very long.
Old Aug 29, 2011 | 08:16 PM
Red Dog's Avatar
It sounds like you need to use the Superior EVO axels as your backups for a while and see if you bend one of the stock ones.
Old Aug 29, 2011 | 08:31 PM
Jknockers's Avatar
Can you explain to me how you found out that your flange/axle is bent? How did you go about testing it or visually see it????
Old Aug 29, 2011 | 10:45 PM
highoctane's Avatar
You can see the wheel wobbling in the mirror on mine. My driver side rear axle is bent(stock), and this is the 5th person I've known bend a Superior Evo rear shaft. I don't know if I plan on upgrading my rear shafts, since the aftermarket ones bend too. Not sure on Superiors warranty.
Old Aug 30, 2011 | 01:16 AM
Jknockers's Avatar
If thats what you heard and I have been told to NOT go with "superior" stuff, I would look at G2 or some other alloy axle shaft. I was researchin axle shafts and thats when I got told to NOT go with "Superior" stuff, I was told to go with G2, but still readin and askin around about brands and reputations.
Old Aug 30, 2011 | 04:24 AM
MikeyB's Avatar
Mine is not noticable to the eye while driving. But I put the rear end on jackstands. Took off the wheels, had a friend put it in drive and let it turn and you can see the brake caliper move side to side. Thought maybe it was the rotors so I had them tested and they are fine. I put a seconds tool that measures how far it is out when it makes a full rotation.
Old Aug 30, 2011 | 04:41 AM
Biggy's Avatar
I bent my rear driver side flange. Went with Foote chromo's from Northridge and they seem to be holdind up fine
Old Aug 30, 2011 | 06:04 AM
wayoflife's Avatar
JK-Forum Founder
if your're absolutely sure that you've really bent a chromoly shaft running 315's, i would give superior a call as they should warranty it. also, you might want to go a bit easier on the skinny pedal as you're bound to break a whole lot more stuff.
