Adjustable lower control arms
Old Aug 30, 2011 | 10:22 AM
msells32's Avatar
Default Adjustable lower control arms
So I won a set of BDS adjustable lowers for front and rear.
Currently I have a 4" pro comp budget lift, and 35" tires.
Can they be installed just by bolt on? What special tools would I need? I'm not a suspension guy but know my way around my tools.
:-) hate seeing them just sitting in the boxes collecting dust..
Old Aug 30, 2011 | 10:40 AM
wayoflife's Avatar
JK-Forum Founder
yes, the lowers can just be installed by bolt on and even with your jeep sitting on all its tires. you'll need a 21mm socket and wrench, floor jack and a torque wrench that can be set to 125 ft. lbs. or more. this write-up will help you out - see the caster section:
http://project-jk.com/jeep-jk-write-...-end-alignment
Old Aug 30, 2011 | 10:56 AM
msells32's Avatar
Ok, thanks for the link... Now just gotta dust off the boxes and install
Old Aug 30, 2011 | 01:16 PM
jeepmedic's Avatar
Its a pretty straight forward install. I did mine in about 2 hours. I followed WOL's write up as well.
