VERY Stuck Ball Joint - Advice Please!
I have a stuck lower ball joint on my JK and I'm using a balljoint press kit and I KNOW I have it positioned correctly. I used plenty of PB Blaster prior too. I've broke TWO 1/2" Drive Craftsman wrenches, a 1/2" Torque Wrench and it won't move anymore. I have used a 18" Crescent wrench and a 3 foot cheater bar (the big cheater bar really helped break those ratchets btw
) and it still won't move any further. Even turning it while heating around the lower with a handheld propane torch it won't move.
Yes, it's stuck. The others came out easily without issue.
My question, if I broke out my Oxy/Acet cutting torch and carefully cut out the middle of the trashed, stuck ball joint would that help? Could this be done without ruining the C on my axle? VERY frustrated right now as you can imagine!
Thanks in advance!
RT
) and it still won't move any further. Even turning it while heating around the lower with a handheld propane torch it won't move.Yes, it's stuck. The others came out easily without issue.
Thanks in advance!
RT
While u have pressure on the bj c clamp, hit it with a hammer to try and jar it loose.. hit and then try to tighten more.
U are sure u are pushing it the right way, and have the cups for the press situated right??
I'm going to heat it while it's under a lot of pressure from the press. Yeah, I have the setup up right.
Thank you.
RT
