Front pinion angle question.
Old Aug 30, 2011 | 12:58 PM
Jeep(NV)'s Avatar
Default Front pinion angle question.
Does anyone think that my stock front driveshaft with this angle could be causing me some vibrations? I am trying to isolate a vibration I have and I can't figure it out. I recently thought it was my tires, but still have it after they got road force balanced today. This vibration is harmonic and happens around 60-70mph's but doesn't changed when I let off the gas, put it to the floor or coast in neutral.
I have a teraflex 2.5" coil lift with front lower control arms set at 22 7/8" drivers side and passenger set at 23". My caster is around 5.5-6.0 degrees, should I get this around the 4 degree range?
Hum! Thanks
ID:	204455   Click image for larger version
Old Aug 30, 2011 | 01:25 PM
wayoflife's Avatar
JK-Forum Founder
you shouldn't be having any vibes with the setup you have but, one way to know for sure is to pull the shaft and take your jeep for a spin.
Old Aug 30, 2011 | 01:33 PM
Jeep(NV)'s Avatar
Ya l was thinking of that. Is their a torque pattern on those upper driveshaft bolts when I reinstall it? Like a star pattern or something?
Old Aug 30, 2011 | 02:00 PM
wayoflife's Avatar
JK-Forum Founder
nope, just reinstall and go. looking at your pics, the angle of your shaft looks pretty good. i would double check to see if maybe you've knocked off any weights on either of your shafts. that would throw it off.
Old Aug 30, 2011 | 02:02 PM
wayoflife's Avatar
JK-Forum Founder
oh, i also see that you have a 2-door with adjustable rear upper arms. do you have a new drive shaft to go with them? if so, could be your pinion angle is off there. that would also cause vibrations as described.
Old Aug 30, 2011 | 03:05 PM
Jeep(NV)'s Avatar
Nope I still have the stock one for now. Here is how it looks. Doesn't seem bad to me?
ID:	204493   Click image for larger version
Old Aug 30, 2011 | 03:39 PM
wayoflife's Avatar
JK-Forum Founder
actually, it looks a bit high at the pinion to me but, that shouldn't make a difference being that it's a cv joint. all things being equal, i would go back to pull the front shaft and seeing if that helps. if so, could be it's just out of balance.
Old Aug 30, 2011 | 03:55 PM
Jeep(NV)'s Avatar
Thanks I will give it a shot!
My rear pinion does look a little high, but I am putting a 1" rear space on the back so that should line it back up.
