bw fender flare
Mine have taken quite a bit of abuse but the front passenger side finally gave up after the second time that I ripped it off from a tree. They will mostly straighten out if you leave them out in the sun. If you run a lot of tight trails steel flairs might be a better way to go. The are pretty strong for a plastic flair look great and am happy otherwise.
i've run BW flarea and think they look great and as mentioned, if you hit your BW flares hard enough, it will tear away from its substructure which, in my opinion, is better than doing body damage. if taking a hit is a concern, i would recommend just running a set of cut down factory fenders. this is ultimately what i've done and not only do they look great, they are essentially free and do awesome on the trail. they bend and fold around trees and rocks and if hit hard enough, just get pulled away from the body. after you pick it back up, you just snap it back in. ask me how i know
there are a couple, one is a steel fender that comes off and the other is plastic option. my question to everyone who think this is a good idea is, where do you store your fenders when you're wheeling? hell, i have a hard enough time trying to figure out where to store my stupid mud flaps in a packed full of gear jeep once i get to the trailhead.
Unfortunately that's not possible, because I am one of the few over here who drives a modified JK. Maybe you share me your thoughts on these fenders (pm maybe)?
