Fumoto Valve on 2012
I have used a Fumoto valve on the last several vehicles I have owned and they have worked great. Does anyone know which version will work on the 2012? Their website says to use F-106 for the 3.6L but I had heard that the Wrangler uses a different oil pan. Would like to go ahead and order one so that when I reach 500miles I can install it. Depends on when I get mine. It seems to be stuck on a railcar outside Chicago. Thanks.
fumotousa.com
Introducing the best way to change oil, the Engine Oil Drain Valve. Install this valve and you can drain your engine oil without tools and without mess. Just lift the lever of this solid brass ball valve and give it a quarter turn to open it. Return the lever to its original position and it locks closed, double sealed to prevent leakage. The Engine Oil Drain Valve is made of corrosion resistant forged brass and stainless steel. The ball valve design provides a straight flow for efficient drainage and a perfect seal when closed. Frozen drain plug and stripped threads are eliminated forever. Drawing samples for oil analysis is as easy as one-two-three. Sizes to fit all cars, light trucks vans heavy-duty trucks and buses. Also fits RVs, marine engines and industrial equipment. (N-Series Valve(w/Nipple)).
N-Series Valve:The Engine Oil Drain Valve is also available with "Nipple" to accept hose. It makes oil changing easy for industrial engines, boat engine and other hard-to-reach applications.
Endorsements:
The Engine Oil Drain Valve has been tested and granted "Genuine Parts" status by 6 major motor vehicle manufacturers in Japan, including Toyota, Nissan, Mazda, Mitsubishi, Subaru and Isuzu. These approvals were not granted easily and gaining them was a testimony to the quality and durability of Engine Oil Drain Valve. In the United States, the Engine Oil Drain Valve is being installed at the factory level on some of the vehicles/equipment made by Ford, Kohler, Freightliner, Caterpillar, JLG, GEHL, Ingersoll-Rand, Sullair, Toyota, Case, Magnetek, Timberjack, Lincoln Electric, Vermeer, Baldor, Terex, Deutz, Phaser Marine Generator and etc.
"We use them on everything with an engine, even our forklifts, and we have for ten years now...I'm not aware of any failures, that's just not been an issue."
Tom Jarvi
VP, Maintenance & Purchasing
Consolidated Freightways
Installation:
Remove original drain plug and drain oil into acceptable receptacle.
Insert Engine Oil Drain Valve with gasket* and tighten. Do not over tighten. (Some oil pans are designed with recessed drain hole which may prevent the valve from being installed properly. If the valve can not be tightened all the way without hitting the oil pan wall, do not install the Drain Valve to your vehicle. Adaptors are available for some models)
Make sure valve is closed and refill crankcase.
*Some valves (i.e. T-200, T201, T-202, F-110) do not require gasket as they are self-tightening tapered threads.
Warning:
For users under extreme conditions:
If you are using the Engine Oil Drain Valve on off-road vehicles such as farm tractors and logging equipment under extreme environment (i.e. corn fields, brush areas), it is recommended that a hose clip as shown below be used for extra safety and security. The hose clip, which can be purchased at any hardware stores, will firmly keep the lever in the locked position at all times.
Drain Valve Size Hose Clip Size
T, FG Series 11/16" Clip
F Series 5/8" Clip
Operation:
To open lift control lever and turn counter-clockwise 90 degrees.
To close simply turn the lever clockwise 90 degrees until locked in original position.
Safety:
Drive carefully at all times, and if you run over any foreign object on the road pull over and check the valve for any damage or leak.
N-Series valve (with nipple to accept hose) is not recommended for passenger cars with low clearance.
Limited Warranty
Fumoto Engineering of America offers a LIFE TIME WARRANTY on its product, against faulty workmanship and/or material to the original purchaser (with proof of purchase). For any defective product, Fumoto Engineering of America will replace the product at no charge. Fumoto Engineering of America will also indemnify any consequencial damages to the engine/vehicle which are directly caused by the defective product. This warranty does not cover any damages due to misuse, abuse, negligence or accident. This warranty is valid only in the United States and Canada.
Endorsements:
Tom Jarvi
Installation:
Warning:
F Series 5/8" Clip
Operation:
Safety:
Limited Warranty
If you don't have one it definitely speeds up the process. There are different versions, right angle, nipple to add a hose to, etc. I use a staight one on my 2008. It doesn't stick below the oil pan at all. Just need to know which one to get for a 2012 and I'll order.
