PRESS RELEASE: NEW Full-Traction Suspension 3.0″ Ultra Plus 0% Maintenance SRS Syetem
NEW! Full-Traction Suspension Jeep JK Wrangler
3.0″ Ultra Plus 0% Maintenance SRS System
Full-Traction Suspension introduces the newest in a series of superior engineered suspension systems for the new 2007-2012 Jeep JK Wrangler 2-Door/4-Door. The New SRS - Ultra Plus Silent Ride System. Combining all the necessary components together in a 100% bolt-on package, this system will allow use of 35″* tires with ease, superior flexibility, improved ride quality, and most innovative, NO LUBRICATION MAINTENANCE ! . Fully adjustable Heavy Duty front and rear lower control arms are manufactured from massive 2.0 x .250” wall DOM steel tubing and come equipped with long lasting zero maintenance OEM style rubber bushings and huge 1.25” Kevlar Lined Chromoly Heim Joints.
This kit runs silent!
Quality laser crafted components allow proper fitment to make this system the one to choose for JK drivers demanding the best. System comes complete with heavy duty adjustable front & rear track bar for proper axle alignment, new generation front sway bar disconnects, rear sway bar links, bump stops, off-set brake line relocation brackets, and ride frequency tuned coil springs for a comfortable ride. Detailed installation instructions included with step-by step photos.
MADE IN THE USA
Part: FTS7137 2-Door
Part: FTS7138 4-Door
Price: $1499.95
* Using recommended tire widths & wheel backspacing
For more information about this lift kit or any Full-Traction Suspension products, please visit their website at www.full-traction.com or call them at (800)255-6464.
Originally Posted by danmojo82
Whats new in the front sway bar disconnects?
The new ones are as pictured with a machined pin and heim joint for disconnecting.
