steel rims vs al. rims
Old Aug 31, 2011 | 02:00 PM
jkd3624's Avatar
Default steel rims vs al. rims
Which are better steel rims or al. Rims
Old Aug 31, 2011 | 02:04 PM
Wandell's Avatar
Loved
I don't think one is "better" than the other. Both have advantages and disadvantages.
Old Aug 31, 2011 | 02:08 PM
Rob 12B1P's Avatar
Alloys are lighter, steel wheels are heavier but stronger. In a bind a steel wheel can be beaten strait whereas an alloy wheel is pretty much done if you manage to bend it.
Old Aug 31, 2011 | 04:54 PM
20JK10's Avatar
Steel is cheaper. But aluminum come in many more designs. Aluminum will also be lighter when they are the same size.
Old Aug 31, 2011 | 05:24 PM
jeeeep's Avatar
I used to run both, alloy for DD and light off-road trips and steel during the winter and long weekend trips where damage is more likely to happen.
I liked the steel in the winter because of the added weight. I also had a more aggressive tread pattern on the steel.
Now I run just alloy for the overall weight and look options -they have also improved on overall strength from many years ago....
