Coil spacers to make up for lift sag.
Old Sep 12, 2011 | 06:42 AM
mgoony's Avatar
Default Coil spacers to make up for lift sag.
Is adding a 1 inch or more coil spacer and acceptable way of getting your ride height back after adding bumpers and winches? Why or why not.
Old Sep 12, 2011 | 06:51 AM
greenenvey's Avatar
Yes, most of us install teraflex leveling kits !!
jesse0376's Avatar
Sure is. Its cheap and works great
Old Sep 12, 2011 | 07:01 AM
mgoony's Avatar
Do you need to re align afterwards?
Old Sep 12, 2011 | 07:03 AM
greenenvey's Avatar
Nope, at least I didn't it drives perfect!! And acually rides better!
Old Sep 12, 2011 | 07:26 AM
mgoony's Avatar
Maybe I wasnt clear enough at the start. I have a 3.5 inch BDS suspension lift right now on my 2011 JKUR Since installed the lift has sagged to the point that its only 3.0 inches taller than a stock Rubi and I have 35 inch trail grapplers
So 35-32 is 3 inches cut that number in half because of the tire alone I should be 1.5inches taller than means my lift is netting out to be only 1.5 over stock. Is this correct? So can I still use the coil levelers?
Old Sep 12, 2011 | 07:33 AM
greenenvey's Avatar
Mabey I'm just cunfused, but do you mean with your lift and 35" tires you are only 1.5" taller than a stock rubi? If so that can't be correct! But either way you can still use the pucks to lift it to compensate for the sag.
Old Sep 12, 2011 | 07:38 AM
mgoony's Avatar
3 inches taller - with 1.5 inches because of the tire size difference.
Old Sep 12, 2011 | 07:41 AM
arasco85's Avatar
I have 2.5 coil lift with. 75 spacer in front and its level. I don't have a huge bumper so yeah 1 inch in front should do fine
Old Sep 12, 2011 | 07:43 AM
Southern Girl's Avatar
Absolutely!
