Intake/exhaust
Old Sep 12, 2011 | 12:11 PM
Gforce!'s Avatar
From: Independence and Lexington, KY (depends on the time of year)
Default Intake/exhaust
Ok so 2 questions for the brilliant minds on this forum.
1. If I install a cold air intake and exhaust on my JK, will that void the warranty on anything?
2. Which ones of each would be best to buy? Preferably only answer this from firsthand or secondhand experience.
Thanks!!
Old Sep 12, 2011 | 12:44 PM
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
1. Short answer is No. Long answer is for something to void your warranty, the manufacturer must prove that the modification you made, caused the failure that you're dealing with. For instance, if you put 40" tires on your JK then bent the axle, the manufacturer would have a good argument that the larger tires caused the axle to bend.
2. Depends on what you're doing. I would generally say the exhaust is best to do first. An exception would be if you drive in heavy dust a lot. If you drive in heavy dust, you'll want to clean your air filter often. That's why I chose the AEM air intake. Cleaning it is easy, so I tend to clean it often. The worst clean air filter is better than the best dirty one.
BTW, I sell both
LINK TO EXHAUST
LINK TO AIR INTAKE
Thanks!!
Old Sep 13, 2011 | 07:58 AM
Gforce!'s Avatar
Thanks for the help! I'm considering this exact setup you posted. Sounds great! Thanks again!
