coast front drive shaft
Old Sep 13, 2011 | 05:50 PM
weebus's Avatar
Default coast front drive shaft
ive seen some posts on here about needing to grease the ball socket in the cardan joint so its about time for a oil change wich is about 3k on new shaft so i dont see any lubepoints except the slideing yoke it has a regular zerk fitting no spots to greaseon joints anywhere i even removed the shaft to be sure what do i do? did the older coast shafts have a place to grease? it doesnt look dry
Old Sep 13, 2011 | 05:58 PM
nthinuf's Avatar
Nice run-on sentence there...
Coast uses sealed spicer joints. If there is no zerk fitting, you can't grease it. Just replace it when you think it needs replacing.
Old Sep 13, 2011 | 06:03 PM
weebus's Avatar
Default drive shaft
sry english class wasnt my strong area anyway i was more asking if anything should be done with the ball part off the cardan joint
