HELP! New Hemi tranny (545RFE) stuck in 2nd gear.
I just installed a 5.7 vvt out of a 2011 Dodge 1500 with the 545RFE auto in to my JK. I converted from a manual. The engine has 3 miles on it and the trans has 7. The computer came from Dave @ B&G Performance and I know he knows his programming. I am a fairly decent hobby mechanic and the install went smoothly in my garage (fired up on first try, no leaks, one code). The TIPM is brand new, so I know that is not the issue.
My problem is this. The trans will only drive in 2nd gear. No matter where I have the shifter (D, 2, 1) it will start out and stay in 2nd gear. Reverse works and I can feel the power of the Hemi, but starting off in 2nd sucks. The lights on the dash match the position of the shifter. The trans is full of ATF +4 and it is not in limp mode because limp mode gives you 2nd and 3rd gear and allows 1st when manually shifting.
My code is P0760 Trans OD Solenoid Circuit. I did install the trans wire in cavity #25 of the C100 and cavity #26 of the C2 (along with the backup light re-assignment) which are both required when converting from a manual. All fuses have power, all pins are connected in the larger plugs.
I am not a trans guy and the kit builder has never encountered this particular problem. He is working dilligently to find a solution.
I am hoping someone has had a similar problem and can say, "yup it's this". There may even be a reward if someone can be quite certain rather than quessing.
On the bright side, this engine sounds awesome (Flowmaster 50 HD) and runs smoothly.
I had a similar issue a couple of years ago but, unfortunately, I can't remember exactly what the trans was doing. My problem turned out to be a wire rubbing through and grounding on the body.
Alright,
Here's what I've learned. The 2011 545RFE has a different valve body (or solenoid) than the 2009-2010 545RFE. This is a little known fact. Since my computer is programmed for a 2009 engine and trans (all 2009, 2010, and 2011 truck Hemi's and trans were thought to be the same), my trans is stuck in limp mode (2nd gear).
I am trying to find out if reprogramming the computer will fix the issue, or I may have to replace the valve body or solenoid with a 2009 part.
Alright,
hi there my jeep 2008 in currantly being fixed for this problem. i have just a standard auto 4 speed and i have done 80,000kms and few weeks ago it locked in second and wouldnt change. took about 2 weeks to find that the main solenoidin the valve body for line pressures and the sensor have failed luckly i have a month of warranty left
hope that helps
hope that helps
