Help with spring rate, off camber situations with a heavy rig
You can see what I am running below. Im running a fairly heavy rig right now. One thing that I dont like is during off camber situations my springs are not "stiff" enough to keep the body more level. With the heavy weight I am really leaning into the grades more than I want. My question is... is there are spring more adept for what I want, or should my jeep go on a diet.
Stock JKU ~4500
+winch 80lbs
+ARB bumper 95lbs
+LOD rear 115lbs
+gear 70lbs
+me 200lbs
+tuffy 30 lbs
+ tire differential from stock 250lbs
+control arms,skids, sleeves etc +100 give or take
= ~5500lbs
+winch 80lbs
+ARB bumper 95lbs
+LOD rear 115lbs
+gear 70lbs
+me 200lbs
+tuffy 30 lbs
= ~5500lbs
Please explain the benefit of this system over a rubi system or any other. My main thing I am looking for is a more level body with flex. It seems the end where the flex is, the spring is not rebounding enough if that makes sense.
I run the Anti rock in the rear, and will be running something like the Teraflex in the front. The anti rock has helped me a lot with off camber situations, and I would highly recommend a system like that.
Another thing that has helped me in off camber situations is this:
ht tp://www.amazon.com/Company-201-F--gage-Inclinometer-Gauge/dp/B00042K694/ref=sr_1_1?ie=UTF8&qid=1316447048&sr=8-1
Once you hit 45 degrees, you know you went too far.
I think that would help more with on road, but off road, if I am disconnected on the trail I dont see how that system would help me?
Please explain the benefit of this system over a rubi system or any other. My main thing I am looking for is a more level body with flex. It seems the end where the flex is, the spring is not rebounding enough if that makes sense.I run the Anti rock in the rear, and will be running something like the Teraflex in the front. The anti rock has helped me a lot with off camber situations, and I would highly recommend a system like that.
