Poison Spyder RockBrawler Rear Bumpers & Tire Carriers
Old Oct 12, 2011 | 11:43 AM
DTS's Avatar
DTS
Former Member
Default Poison Spyder RockBrawler Rear Bumpers & Tire Carriers
Multi-Faceted Design
The RockBrawler™ Rear Bumper's high clearance, multi-faceted design provides the best possible departure angles and corner obstacle clearance. Its appearance is streamlined and sexy, not like the squarish, boxy shape of many other bumpers on the market. The RockBrawler™ is constructed of CNC laser cut, brake-formed 3/16" plate steel. The multiple bends and facets actually lend even more strength to the bumper design. Unlike Poison Spyder's BFH™ Rear Bumper for JK, the RockBrawler™ Rear Bumper can be mounted without cutting or altering the Jeep's frame rails.
Recessed Back-Up Lamps
Very few JK rear bumpers come with provisions for mounting backup lamps. Of those that do, fewer still allow the use of high intensity, low power drawing LED lamps. The RockBrawler™ Rear Bumper's recessed light buckets accept 2-1/2" Round, Clear LED Lamps—the same backup lamps we've sold with our Crusher Corners™. The recessed buckets protect them from the rocks and direct light rearward rather than into the bumper interior, the way some competitor's bracket-mounted lamps do. Customers may choose to wire them into the reverse light circuit, or wire them to a separate dash switch as a loading or utility light. IMPORTANT: Note that the LED Lamps do NOT come with this bumper, they must be purchased separately.
Integrated Spare Tire Carrier
The RockBrawler™ spare tire carrier is built from the highest quality components. The main structure of the tire carrier is fabricated from NC-bent DOM tubing and laser-cut, precision brake-formed plate steel. The extreme duty hinge assembly includes a CNC machined spindle and housing, with a pair of Timken tapered roller bearings for smooth operation under the heaviest loads. The latch is a high quality automotive grade mechanism, concealed in a fabricated housing. There is a spring-loaded pin-lock with stainless steel slider plate that locks the tire carrier into the open position to keep it from swinging around while accessing the Jeep's tailgate. The latch and pin lock are both easily disengaged with a simple pull of a knob. The tire mount is adjustable up and down, as well as in and out, to accomodate a wide variety of tire sizes up to 42". The adjustability allows the tire to be mounted as low as possible for any tire size, to keep a low center of gravity. The included license plate mount places the license plate at the center of the spare tire.
A custom Hi-Lift Jack Mount, available separately, is CNC laster cut and bolts to the top of the tire carrier. Also available separately is our LED License Plate & Third Brake Light with 6' Extension, to properly illuminate your relocated license plate.
Rock Solid Mounting
The JK RockBrawler™ Rear Bumper incorporates an extra set of mounting bolts, along the bottom of the bumper which fasten into the rear crossmember. Combined with the mounting flange bolts at either side, the bumper is rigidly fastened by a total of 8 Grade 8 bolts, on three different planes to provide ultimate strength and rigidity to the mounted bumper.
Recovery Shackle Tabs
The optional Heavy Duty Recovery Shackle Tabs are CNC machined from 1" thick steel billet, specifically designed to accept our heavy duty 3/4" Recovery Shackles. These tabs are designed to match the high clearance aspects of the rest of the bumper and minimized hang-ups. Selecting this option will get you a pair of these tabs, expertly welded to the RockBrawler™ Rear Bumper.
Works with Existing Equipment
The RockBrawler™ Rear Bumper is designed to work with your existing OE tow hitch. Unlike the integrated hitches found on competitor's bumpers, the OE hitch is designed for and safely rated for towing. And best of all, its easily removable. So those who need a sturdy hitch for towing can still use the stock one, while those who need the extra clearance for hard core off-roading can easily remove it. The RockBrawler™ Rear Bumper has a built-in step/recess to provide easy access to the rear of the Jeep as well as clearance for the spare tire. The RockBrawler Rear Bumper is available without an integrated spare tire carrier, so that it may be used with the stock spare tire carrier and up to a 35" tire.
When relocating your license plate to the center of the spare tire, you may wish to cover the hole left in the Jeep's body when the OE license plate mount is removed. A License Plate Delete Cover is offered by Poison Spyder for this purpose. Poison Spyder also offers an LED License Plate Lamp and Third Brake Light to illuminate the license plate in its new location at the center of the spare tire. LED's provide bright light with low power draw. Mounts to the two upper license plate bolts and includes a 6-foot wiring harness extension with weatherpak connector, for relocating the license plate to the spare tire carrier or other locations that are far from the OE location.
Click Here for RockBrawler™ Rear Bumper without Tire Carrier
Click Here for RockBrawler™ Rear Bumper with Tire Carrier
Click Here for RockBrawler™ Hi-Lift Jack Mount
Click Here for LED Back-Up Lamps
Click Here for the License Plate Delete Cover
Click Here for LED License Plate Lamp & Third Brake Light
Old Oct 18, 2011 | 07:14 PM
ISSY's Avatar
I really want this setup! Won't be getting my 35's till the spring, how bad would a 33 look hanging off the back of this?
Anyone running this with a tire that small??
Old Oct 19, 2011 | 02:35 AM
sneck's Avatar
I love the rear bumper, and decent price too, but I know there's no chance of being able to pickup the complete bumper and carrier at once (thats the cost of a new set of wheels and tires!) Is it possible to add the carrier after? Or is it best to order as one piece?
Old Oct 19, 2011 | 10:33 AM
BJK's Avatar
BJK
Beauty of this tire carrier is you can adjust the height in which the spare will sit.
Old Oct 19, 2011 | 11:11 AM
DTS's Avatar
DTS
Former Member
The tire carrier is not available as an add-on. You'd never be able to get it installed and aligned correctly without our assembly fixtures. Best bet is to save up a little longer and get it with the tire carrier. Or keep an eye on our Garage Sale page, as I have one or two blems/returns that will be going on sale there at a significant savings.
Old Oct 19, 2011 | 06:38 PM
ISSY's Avatar
Any idea when those blems are gonna show up on your garage sale page? I've got some money buring up a whole in my pocket!
Old Oct 19, 2011 | 06:52 PM
Navyvetnorwich91's Avatar
Veteran: Navy
Hey ISSY, I have this setup with 285s about 33.8 and I think it looks pretty good. Gotten a lot of compliments. Flying on a Southwest plane right now so cannot post pics but I have a bunch in my profile.
Old Oct 19, 2011 | 07:34 PM
shoe1724's Avatar
Sweet looking bumper. Too bad I don't have any money burning a hole in my pocket right now.
Old Oct 20, 2011 | 02:25 AM
Bnizzle's Avatar
Old Oct 20, 2011 | 09:32 AM
DTS's Avatar
DTS
Former Member
Just put them up, have at 'em. There are actually three available. They're all our first generation version, without the recessed backup lights.
