ARB Twin Air Compressor Kit Last - One In The USA !! (According to ARB)
Old Oct 12, 2011 | 03:23 PM
ORWJK's Avatar
Sponsoring Vendor
ORW Representative
Default ARB Twin Air Compressor Kit Last - One In The USA !! (According to ARB)
We had sold a (6) of these units at the Off Road Expo in Pomona last week end, now according to ARB we have the last one available in the US.
Name:	ARB Compressor 2.jpg
ID:	222700Click image for larger version
Name:	ARB Compressor 1.jpg
I am offering a JK Forum Special to Forum members only (no walk in sales at the stores) for $$495.00. Check out the features, look at the pictures, first come first sold!
Constructed primarily of light weight, high strength, engineering grade materials, including military and aerospace standard components.
Pressure switch controlled air manifold system regulates pressure between 9.3Bar [135PSI] and 10.3Bar [150PSI] suited to air tools and all
ARB Air Locker equipped vehicles.Highest air flow rate of any 12V compressor of its size on the market at 174LPM [6.16CFM]. High efficiency design consumes only 56 Amps at maximum air flow. Built with sealed components for moisture and dust resistance. Hard-anodized cylinder bores and PTFE (Teflon) impregnated carbon fiber piston seals for reduced friction and maximum trouble free life. Ducted IP55 sealed brushless DC cooling fan and anodized motor mounting brackets effectively dissipate heat from the motors, heads and electronics allowing for a 100% duty cycle (under room temperature conditions). Anti-vibration / sound deadening is integrated into the mount. Relocatable splash resistant air filter assemblies for cleaner, cooler air supply and versatile waterproof air intake positioning. High density and high flow washable sintered bronze air filter elements. Full wiring loom included for simplified installation and easy plug-in.
Looking forward to taking the order from the lucky Form Member that wants to buy the last compressor at this great price, PM/E-mail, or Call.
JK
Old Oct 13, 2011 | 10:07 AM
Baddintentions4u's Avatar
Dammit David!!!
You're going to make me either to BROKE or DIVORCED....lol. I want this like a fat kid wants cake!! Now looks like I have to choice between my Coast Driveshafts or this.... What to do? What to do?
Old Oct 13, 2011 | 11:08 AM
ORWJK's Avatar
Sponsoring Vendor
ORW Representative
Originally Posted by Baddintentions4u
Dammit David!!!
I still have it in stock, to place the order, I will need the following:
Name
Address
Zip Code
City
State/Province
Country
E-mail address
Phone Number
Credit Card Number
Type
Number
Code
Expiration Date
Either PM/E-mail, or Call and I will take your order and ship your compressor.
Thank you for your intrest,
John
The new ORWJK
Old Oct 13, 2011 | 11:21 AM
UGOTKERN's Avatar
Maybe I'm missing something..... what's the forum special since these typically sell for $495 anyways?
Old Oct 13, 2011 | 11:41 AM
ORWJK's Avatar
Sponsoring Vendor
ORW Representative
The special is, that ORW has the only one in the U.S. (According to ARB at the Off Road Expo) and we are offering it for $495.00.
Old Oct 13, 2011 | 12:14 PM
Spetz's Avatar
Does this still mount in the engine or is it too large with the dual compressors?
Old Oct 13, 2011 | 12:26 PM
saravonshep's Avatar
Why are they not in the U.S anymore??
Old Oct 13, 2011 | 12:47 PM
zaknafien's Avatar
I have the ARB single compressor already mounted underhood and wired up. Does this have the ability to mount in a similar location? And if so, has someone done the legwork on a mounting plate like has been done for the origional ARB on-board-air compressor? Or better yet, will it attach with the already in place master-cylinder mounted plate? If it's usable like that, I'd be tempted to upgrade, as I did hit thermal cutout on the single compressor doing some airing up after a day with a local Jeep group... Of course, it was 100+ out and it aired up 5 Jeeps before conking out, so I can't fault it. Just would like to have the added boost of the second compressor for both output speed and the surety that I'll have at least one kicking when I'm relying on this for air lockers.
Old Oct 13, 2011 | 01:43 PM
ORWJK's Avatar
Sponsoring Vendor
ORW Representative
Spetz,
I am not sure that I can honestly answer your question, but I asked ARB for a E-copy of the installation guide for the CKMTA12 (Dual Compressor) and I will attach it to this E-mail. CHANGE 2, PLEASE SEND ME YOUR E-MAIL ADDRESS, THE PDF IS TOO LARGE TO ATTACH.
Hope this helps, PM/E-mail, or Call with any questions or need of information,
John
Old Oct 13, 2011 | 01:45 PM
ORWJK's Avatar
Sponsoring Vendor
ORW Representative
I was told by the ORW GM that ARB had 160 compressors back ordered at this time, eventully they will be available again on the market.
John
