AEV's ProCal Module For The 2012 Jeep JK's Are Now In Stock
Old Oct 13, 2011 | 03:41 PM
ORWJK's Avatar
Sponsoring Vendor
ORW Representative
Default AEV's ProCal Module For The 2012 Jeep JK's Are Now In Stock at ORW
AEV Launches 2012 Compatible ProCal
AEV Updates ProCal, Now Includes 2012 JK Wranglers
AEV is pleased to announce the launch of the updated ProCal Module. This new version will continue to offer all of the same great recalibration capabilities, but it now offers enhanced features and is fully compatible with the 2012 JK Wrangler. This means that for customers with 2012 JKs who want ring and pinion changes, there is no more concern about the vehicle going into limp-mode after the change has been made.
Overall, the updated ProCal Module remains a plug-and-play solution. To use it simply set its dip switches according to AEV's instructions, turn the ignition to Run, plug the ProCal Module into the JK's OBD port, and the horn will honk immediately signifying that your recalibration is complete. It's fast and simple!
As a reminder of what the ProCal Module can do, here is a quick review of its great recalibration capabilities:
1) Speedometer and Gear Ratio Correction to compensate for tire size and gear ratio changes. After changing tire size, it's important to correct speedometer accuracy for proper mileage, automatic transmission shift points, ESP (Stability Control) and general performance. This is for all JK variants with all transmissions.
2) Tire Pressure Monitoring System (TPMS) control for running lower-than-stock tire pressures without activating the JK's low tire pressure warning light.
3) Daytime Running Lamp Enable or Disable function. This allows you to select the style and location of DRLs to use, or disable the system completely. Note: This function has been improved in the updated ProCal Module.
4) Temporary engine high-idle capability for increased performance of Jeep-mounted winches, welders and air compressors. Works with all Gas engines including 3.6L, but Diesel only up to 2010. Note: This feature has been improved in the updated ProCal Module. There is no longer a 4.5 minute time out, which makes it more useful for welding.
5) Engine diagnostic code clearing.
6) Steering wheel on-center verification, for use on an alignment rack to ensure a perfectly centered steering wheel.
7) Much more...
ORW now has the newly upgraded ProCal Module in stock and ready to ship!
Pricing: $149.00
Name:	AEV 2012 JK ProCal Module.jpg
Old Oct 14, 2011 | 07:11 PM
bo9roadking's Avatar
Will there be an upgrade or update available for people that already have a ProCal? I purchased a new one about 2 months ago and used it 2 days ago on my 2012 to change the tire size.
Old Oct 15, 2011 | 04:14 PM
KSRubicon's Avatar
Happy Dance!!
I just ordered my new Unlimited with the AEV 4.5" Dual Sport RS lift, and the installer was worried that they didn't have the 2012 procal.
Old Oct 15, 2011 | 05:48 PM
ORWJK's Avatar
Sponsoring Vendor
ORW Representative
Originally Posted by KSRubicon
Happy Dance!!
KSRubicon,
We have Dozens of them in stock!
PM/E-mail, or Call to place your order.
John
ORWJK
Old Oct 16, 2011 | 07:03 PM
ORWJK's Avatar
Sponsoring Vendor
ORW Representative
Sorry to hear that. I suggest that you call the Tech Rep at AEV, I spoke to them on Friday and they were very helpful and informative. They would be the best people who can tell you if your module can be upgraded for the 2012 JK's
Best of luck,
John
(If you can not contact an AEV Tech Rep, PM/E-mail, or Call me and I will see what I can do to help).
Old Oct 17, 2011 | 04:54 AM
wolfman6012's Avatar
Sounds great low price count me in
Old Oct 17, 2011 | 10:29 AM
ORWJK's Avatar
Sponsoring Vendor
ORW Representative
I did not understand your last post. Should I take that you would like to place an order?
If you would like to place an order I will need the following information:
Name
Address
Zip Code
City
State/Province
Country
E-mail address
Phone Number
Credit Card Number
Type
Number
Code
Expiration Date
PM/E-mail, or Call with the information, or if you have any questions,
John
Old Oct 17, 2011 | 10:44 AM
ORWJK's Avatar
Sponsoring Vendor
ORW Representative
GREAT NEWS!!!!!
I just got off the phone with the AEV Tech Rep for ProCal. He informed me that they will have a program adjustment available in the next few weeks, that will upgrade the 2011 ProCal Modules to make them full functional for the 2012 JK's !!!
Keep an eye on the AEV web site for this upgrade.
John
