What's new in the shop today
Old Oct 24, 2011 | 03:03 PM
ORWJK's Avatar
Sponsoring Vendor
ORW Representative
Default What's new in the shop today 0002
WHAT'S IN THE SHOP TODAY 0002
ID:	227884Click image for larger version
ID:	227885Click image for larger version
ID:	227886Click image for larger version
ID:	227887Click image for larger version
We are proud to be able to work on this 2010 JK Sahara 4 Door, who's owner comes from our Military Community.
This JK is being transformed inside and out. We installed a Jeep Superchips Flashpaq 3875. The Jeep Flashpaq performance tuner delivers extra power to the wheels, exclusive off-road features, and a re-calibration of the Jeep's electronics for tire, axle gear, and transfer case gear changes. Flashpaq has developed this tuner and features around how you use your Jeep.
The 3” lift came from a Teraflex JK Wrangler Lift Kit. This system includes front sway bars disconnects, rear sway bar links, rear track bar bracket, bump stops and all necessary hardware. We also installed a Teraflex Front Adjustable Track Bar. This massive heavy duty front adjustable track bar is designed to eliminate any front end shimmy or handling issues. This kit will allow you to run to a 35” tire (aftermarket wheels with 4.5” backspacing or less are required). The kit will fit all JK Wrangles including Rubicon and Unlimited.
The customer requested that we mount the Toyo 35x12.50x17” tires on his stock wheels.
To provide the required 4.5” of backspacing, we used Teraflex Wheel Offset Adapters.
The wheel offset adapter is designated for those desiring to retain their stock wheels, but run larger tires.
The customer was very satisfied with the work that was performed in our shop and the products that he chose for his Jeep JK. We provide sales and service to many Military Members, and we would like to THANK THEM ALL FOR THEIR SERVICE.
John
ORW-JK
