Crankshaft Position Sensor....
Old Nov 11, 2011 | 06:46 AM
jeeprin's Avatar
Default Camshaft Position Sensor....
All,
Ok, So i installed my RIPP Supercharger and the Jeep is throwing the code P0340, which is the Camshaft position sensor. I know there is a TSB for this in the '07s, and I have having the same issues: 5-10 seconds before crank to start, will to stall from idle to acceleration, learching, limping. I do not think that this is related to RIPP tuning, but I addressed this to them anyway. I unplugged the wiring harness that connects to the CPS and re-checked to ensure they were seated properly...no issues there. Anyone have any ideas what else could throw this code?
The reason I ask is because, if I have to replace the sensor it is potentially another long day of work. The location of the sensor is directly behind the SC support brackets....anyone else who has installed a RIPP will understand my dilemma because, I will have to completely remove the SC to get at it
Is there anyone out there that has some insight to rule out other things before I tear this thing out, replace the sensor, only to discover this was not the issue in the first place (potentially)?
Thanks.
Brandon
Old Nov 11, 2011 | 06:49 AM
ronjenx's Avatar
The RIPP has brackets on the back of the engine? That's where the crankshaft position sensor is.
Now, if you are talking about the camshaft position sensor...
P0340-CAMSHAFT POSITION SENSOR CIRCUIT
  • When Monitored: During engine cranking and with the engine running. Battery voltage greater than 10 volts.
  • Set Condition: At least 5 seconds or 2.5 engine revolutions have elapsed with crankshaft position sensor signals present but no camshaft position sensor signal. One Trip Fault. Three good trips to turn off the MIL.
[TABLE]
[TR]
[TD="bgcolor: white, align: center"]Possible Causes
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]5-VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]5-VOLT SUPPLY CIRCUIT OPEN
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]CMP SIGNAL CIRCUIT SHORTED TO VOLTAGE
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]CMP SIGNAL CIRCUIT OPEN
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]CMP SIGNAL CIRCUIT SHORTED GROUND
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]CMP SIGNAL CIRCUIT SHORTED TO THE 5-VOLT SUPPLY CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]SENSOR GROUND CIRCUIT OPEN
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]CAMSHAFT POSITION SENSOR
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]CRANKSHAFT POSITION SENSOR
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]POWERTRAIN CONTROL MODULE (PCM)
[/TD]
[/TR]
[/TABLE]
Old Nov 11, 2011 | 07:08 AM
jeeprin's Avatar
Correct, It is the camshaft position sensor. I misquoted, I apologize.
[TABLE]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[/TABLE]
Old Nov 11, 2011 | 07:42 AM
jeeprin's Avatar
Just rechecked everything and the codes went away...started just fine. I hope it stays this way. Thanks for the reply, Ronjenx. Time to go have some fun!
