How high can lift
Ok, I have a 2010 and i want to put a 3inch lift. If I do that would I need to replace my driveshaft and the angle? Can I keep it stock? Would I be doing harm on the diffs, drivetrain, tranny etc?
I have a 3" lift, which came out to about 3.5 or 4. I tore my front driveshaft tcase flange boot first trip disconnected. It is really all random.
If I didn't wheel, or did it still connected, it prolly wouldn't have torn. Then again, wouldn't have made it down the trail either.
being that you have a 4 door, you will not need to change out the rear drive shaft. if you have an auto, i would highly recommend that you change out the front shaft as it will come into contact with your tranny sump pan, tear off the boot and start damaging the seal between the pan and the tranny over time. if you have a 6-speed, you do not have to change out anything. regarding everything else, the question you really need to be asking is how big of a tire you hope to run as you might want to regear. aside from that, you will be fine.
Originally Posted by Rottenbelly
I know a couple guy in our club are running 6 inch longarm kits with the stock driveshaft.
They did trim the skid a little and have there pinion angles set. Been about a year with no problems.
I run 4 inch lift and did the same trimming on my skid. Mine only comes close to it on a vehicle lift at full droop.
actually, it won't do a whole lot of anything to prevent your front drive shaft boot from getting torn as the real culprit is the lip of the tranny sump pan. you can remove the skid completely and you will still tear off your boot and start to damage your tranny pan.
