Poison Spyder Bumper
Old Nov 12, 2011 | 09:24 AM
gtucker0825's Avatar
Default Poison Spyder Bumper
I am installing the PSC Rear Rockbrawler... I would like any suggestions to help the install go smooth...
Pics, thoughts, tips...
Thanks in advance...
Old Nov 12, 2011 | 11:42 AM
jezzalachis's Avatar
Old Nov 12, 2011 | 12:17 PM
_J__C_'s Avatar
Originally Posted by jezzalachis
Fourth - I used reguar 1" ratchet straps attatched to the chassis and wrapped around the bumper to pull them into place and align it up with the bolt-holes. One on each side made this so easy and I avoided using a rubber mallet to bang the damn thing into place (did I mention that my epoxy coat was too thick? ). Probably the best way to pull these things into place.
Lastly, tighten everything into place!!!!
Enjoy, these rear bumpers (IMHO) are the best on the market!!!!
I recently bought/installed the BFH Fr/Rr bumpers. the ratchet advise is probably good, it was a tight fit and I wish after reading this that I would have done that. I didn't have a drill bit problem, I drilled a pilot hole and was good after that.
I did have a problem at the bottom of the tub. I had to cut a notch in the bottom of the tub. This was easier than cutting a notch in the bumper. The flange that bolts to the frame hit the bottom of the tub, not much but it rattled like mad before I cut it. Install it, check it, and then see if it hits before you cut anything. I like the look and strength of the bumpers and I'm happy I went with them over other options, just be aware they may not be just be a bolt on and run thing. The front had no issues.
Old Nov 12, 2011 | 01:55 PM
