lift help
Old Nov 14, 2011 | 12:39 PM
big c's Avatar
Default lift help
I'm looking at doing a teraflex leveling kit with rubi springs and shocks would I need to change anything or would it be just bolt on good to go
Old Nov 14, 2011 | 04:39 PM
big c's Avatar
Bump bump bump
Old Nov 14, 2011 | 04:42 PM
wayoflife's Avatar
JK-Forum Founder
for the most part, you should be good to go. if you're running factory wheels, you may find it necessary to install wheel spacers or, relocate the rear sway bar links to the inside of the mounts as they may otherwise sit dangerously close to the sidewalls of your rear tires.
Old Nov 14, 2011 | 09:27 PM
big c's Avatar
Would it be easier to just get a lift
Old Nov 14, 2011 | 09:29 PM
Probo's Avatar
You'll level your jeep.... Then ull get it back and want a lift I bet lol. It's hat happens
