Best way to go about lifting
Old Nov 15, 2011 | 01:23 PM
ArmyEng875's Avatar
Default Best way to go about lifting
Running BFG KM2 285/70R17... Would like to achieve 2.5" lift...without spending a butt load of money.
Should I look at doing a smaller lift + body lift or just stick to a suspension lift? Also, should I change out springs and shocks or what?
Old Nov 15, 2011 | 01:25 PM
jmdupas's Avatar
i just ordered a 2012 and asked dealer about warranty if i put on a lift. This dealer said suspsension lift, no problem. Body lift, more likely to void warranty. Seems like it varies from dlr to dlr.
Old Nov 15, 2011 | 02:39 PM
nthinuf's Avatar
Do you plan on adding heavy bumpers/winch/tire carrier/armor/etc?
No - Look at the 2-2.5" BB's. If you want a bit more height, add a 1-1.25" body lift.
Yes - Look at the TF coil leveling kit, or any of the 2-2.5" coil kits.
At these heights, caster correction is nice, but not needed. Axle centering is nice but not needed. Less chance of driveshaft issues. etc.
Old Nov 15, 2011 | 03:00 PM
ArmyEng875's Avatar
Will be adding smittybilt front and rear bumper with tire carrier, rocker armor and winch..
A budget boost wont give me anymore flex room will it?
Is this going to be about the best bang for the buck I can get?
http://www.quadratec.com/products/16190_2500_07.htm
Old Nov 15, 2011 | 03:03 PM
Hook-Em's Avatar
If you know you want to stay in the 2-2.5 range, I don't think you can beat the Teraflex budget boosts.
Old Nov 15, 2011 | 04:33 PM
ArmyEng875's Avatar
Originally Posted by TheDirtman
Look into evo's new kit 2" coil in front with 3/4" puck for the rear sized for heavy bumpers and you can use your factory shocks, levels and is only $330 Its all you need for 33's
Im also wanting something to make it more capable off road.
Old Nov 15, 2011 | 04:37 PM
StrizzyChris's Avatar
If you put a body lift on and have to take it to dealer...2 hours and its back off...no one the wiser!
