Springs + Lift
Depends on the springs. I went from 14/56 to 18/58 and got roughly an inch added height.
Tons of info here...
https://www.jk-forum.com/forums/show...rings-Question
As mentioned above, it depends on the spring rates.
However, chances are that yes, you'll end up with 3.5" or even more. I don't know your finances, but if you're strapped for cash, I wouldn't add all that at once without knowing the outcome. 3.5"+ on a two door is going to leave you wanting track bars and front LCAs, and is likely to greatly accelerate the wear and tear on your driveshaft boots.
There's a reason you don't see a lot of "budget boosts" over 2.5".
Edit - Although come to think of it, I have heard of a handful of 2 door JKs coming from the factory with some of the highest spring rates. I would assume they could still safely install a 2.5" BB. So you may just end up with perhaps some flightier handling than you would have had had you kept your stock springs. I don't know . . . I'd be inclined to install the springs first (assuming the coil numbers indicate it would benefit you) and then decide whether to add the BB.
