steering pump leaking!!
Old Nov 18, 2011 | 12:21 PM
BlackBandit's Avatar
Default steering pump leaking!!
Steering pump started to leak the other night out of bottom by pitman arm just out of warranty I do have a 4" Rancho lift but it has drop pitman arm any ideas I see jeep is almost a grand and through rock auto 100 bucks rebuild what is everyone doing???
Old Nov 18, 2011 | 12:40 PM
sneck's Avatar
!!! I had no idea they cost that much, mine just blew up at the 3k mark, so it was covered under warranty. That sucks
Old Nov 18, 2011 | 05:12 PM
Any other ideas??
Old Nov 18, 2011 | 05:28 PM
fishtale's Avatar
Just to be clear it sounds like your steering gear box, not pump. You could possible just have a loose steering line. Try tightening them. Not a cheap solution if you have to replace. I thought would be to get with West Texas Offroad and do the hydro kit. They will rebuild your box and provide lines and ram for $500. You can even just cap off the ports if you don't want to do hydro yet and sell the lines and ram. Just a thought.
Sent from my DROIDX using Tapatalk
Old Nov 19, 2011 | 08:56 AM
It is a sterring box checked lines they are tight leaks right out the bottom sucks for me I believe
