Death wobble - with rubi springs and shocks
Had my stock sport springs and shocks replaced with rubi springs and shocks. Had that done on Tuesday and experienced a little wobble when I hit a bump at high speeds. Then today I hit a bump at 50mph and experienced really bad death wobble. I did not think I would get this with just replacing springs and shocks. I also have JKS disconnects put on, which I don't think would cause a problem. Could it be that my lift 1.5in in he front 1 inch in the rear is too big for my Goodyear SRA tires? I didn't think so since I didn't get that much lift. Ideas?
Originally Posted by newbiejeeper
I don't know. I had a local Offroad shop do the work for me. I have a call into them.
I agree, start at the trackbar and make sure it's torqued on right.
You should read the following thread and educate yourself so when you are talking to you local shop you are on the same page.
https://www.jk-forum.com/forums/show...t=death+wobble
Good luck!
Brent
Good luck!
Brent
Lower trackbar bolt was about half a turn loose. Torqued it back up. The rest of the components were tight. Shop wants me to keep an eye on it and bring it back and leave it if it happens again. Drive home was uneventful. So we will see.
