Bent swaybar
After installing JKS quick disco's, it seems like the swaybar is bent inwards on the passenger side. You can see how the disco is at an angle:
This is driver's side, which is perfect straight:
My question, is it something to worry about or should I leave it? I'm more concerned about something happening to passenger side disco.
It shouldnt be an issue. But yes the sway just floats in 2 brackets. You can wiggle it back and forth(up/down while pulling/pushing) or you can persuade it with a hammer if you are feeling frisky. Or you can bend it out a tiny bit with a crowbar.
