Screw you 17/32"!!!
Old Nov 20, 2011 | 02:29 PM
Nwapache's Avatar
Default Screw you 17/32"!!!
A hint for Poison Spider....please include a 17/32" drill bit in your kits. I planned on finishing up my flare install today and went 0 for 4 finding this effing drill bit. It's such a crazy size, no one stocks it.
Just a friendly heads up for anyone doing nut sert installs....order the drill bit first
Old Nov 20, 2011 | 02:40 PM
TROUPP's Avatar
Must be a west coast thing.. I have 3 of those in my drill bit drawer and I've never bought one of the fancy every size under the sun drill bit kits.. Hope better luck finds you tomorrow.
Old Nov 20, 2011 | 02:43 PM
dcharge74's Avatar
Try a plumbing & heating supply house in your area. They should have every size from 1/16" up to 1/2", and you should be able to buy them indivually. And buy an extra, because you will always break the bit on the second to last hole.
Old Nov 20, 2011 | 02:45 PM
fadeout's Avatar
^^ truer words have never been spoken.
Old Nov 20, 2011 | 03:04 PM
RSTRICK's Avatar
Try a industrial supply like Fastenal they will have it. I have that one in my Snap-on set. Hope you find one.
Old Nov 20, 2011 | 05:04 PM
Nwapache's Avatar
Thanks for all the helpful replies, I will call some more specialized stores tomorrow!
Old Nov 20, 2011 | 05:11 PM
Captianjack2010's Avatar
Try lowes or home depot for an Irwin bit. They cost 40 to 50 bucks. They start at an 1/8" and can go up to an 11/8" all on the same bit.
Old Nov 20, 2011 | 05:12 PM
I meant a Irwin Unibit.
Old Nov 20, 2011 | 05:17 PM
autox-racer's Avatar
Sorry I just realized it is more than half inch. Although I doubt hf holds a 1/32 tolerance.
Buy a cheap 115 piece set from harbor freight...they will have something close enough. Just need a grinder to sharpen every once in awhile.
Or invest in high quality set to last a life time. .My hf crappy set has lasted years with regular sharpening.
Old Nov 20, 2011 | 05:22 PM
scooby snacks's Avatar
x2!! HF bit set or the 3 Piece Titanium Nitride Coated High Speed Steel Step Drill Bits. You can get them for $8.99 with a coupon.
