lift kits
Old Nov 20, 2011 | 04:53 PM
JK x 2's Avatar
Default lift kits
what is a good lift for a good cheap price including shocks and all that wont look to big with my 265 toyo open country mts until i can get my 35s
Old Nov 20, 2011 | 04:58 PM
JK x 2's Avatar
Default thanks
im not looking to lift it again after i get my 35s if that helps
Old Nov 20, 2011 | 05:55 PM
firefighter53111's Avatar
I'm in the same boat. I think I'm going to wait on the lift until I get the tires. Im thinking Rough Country 3.5 but it'll look kinda dumb with stock sport tires.
Old Nov 20, 2011 | 06:38 PM
Paradise's Avatar
That's an understatement!
Old Nov 21, 2011 | 08:54 AM
Jtrain496's Avatar
I agree the teraflex 2.5 will be perfect for you. You can get it with new shocks or stock shock spacers. Looks perfect with 35s
Old Nov 21, 2011 | 08:58 AM
DarkS1de's Avatar
I ordered the TF 2.5 coil lift and 5100 Bilstein shocks from Dave at Northridge. Give him a call. Going to run it with 33 duratracs.
Old Nov 21, 2011 | 09:14 AM
msquaredIN's Avatar
I just ordered that same setup! Going to run 35 MTR/Ks
Old Nov 21, 2011 | 09:20 AM
Vincor's Avatar
Sorry to jack the thread, but I am new to the Jeep world and will be going with the Tera Flex 2.5" lift with shock adjusters. Is there anything else I need to do? I will be running 18" wheels with 35 Nitto's.
Old Nov 21, 2011 | 09:26 AM
DarkS1de's Avatar
Great minds think alike!
Old Nov 21, 2011 | 10:01 AM
Hook-Em's Avatar
Originally Posted by mpkelley20
What 18" wheels are you going to run? Stock Sahara wheels or aftermarket? I think you "could" have issues depending on the backspacing...but not positive.
X2 on running 35" Nitto tires on stock 18" rims. You will definitely have some issues. When I put my 4" lift on Discount Tire was nice enough to get a set of 5 Nitto Terra Grapplers in for me. They even dismounted one of my stock Duelers and mounted a Nitto onto my 18" Sahara rims. I had contact in the rear with the sway bar. On the front I had contact well before full turn with my air dam and sway bar.
The end result for me was replacing my 18" Sahara rims with 17" aftermarket rims. You can see my setup below, in my signature.
Good luck in you choice.
