What air pressure do you run in your 35"s?
Old Nov 21, 2011 | 12:56 PM
Rick in Colorado's Avatar
Default What air pressure do you run in your 35"s?
3.5" AEV lift kit on a 2-dr 2012 JK. Dave at AEV suggests 28psi. Discount Tire says 35psi.
Old Nov 21, 2011 | 01:09 PM
4WHLN's Avatar
Im running 28 in my grapplers.
Do a search. There has been a couple threads on this topic.
Old Nov 21, 2011 | 01:14 PM
dinojeep's Avatar
From the FAQs:
Q: On the road, what PSI should I be running in my tires?
A: For optimal comfort and even tire wear. you should not run the recommended PSI listed on the sidewalls of your tires. Typically this will be way too much. On average for a 33" tire, I would recommend that you run your tires at approximately 28-30 PSI. For a 35" tire, I would recommend running approximately 26-28 PSI. For a 37" tire, I would recommend approximately 24-26 PSI.
I run my 35s at 29-30 psi. 35 psi would be too much.
Old Nov 21, 2011 | 01:20 PM
ChryslerChris's Avatar
28 psi. It's what I run. 35 will beat you up. The tire places think all vehicles are Honda civics.
Old Nov 21, 2011 | 01:22 PM
Hook-Em's Avatar
I'm running 32-35 psi in my 315/70R17's and love the ride and handling characteristics.
Old Nov 21, 2011 | 01:27 PM
Ryan0260's Avatar
Running 30 in mine
Old Nov 21, 2011 | 01:47 PM
tslewisz's Avatar
28 psi with 8" wheels and 315's
Old Nov 21, 2011 | 02:21 PM
photographix33's Avatar
38 on the street with MT Baja Claw 35's was suggested by MT Rep.
Old Nov 21, 2011 | 02:31 PM
Friday2322's Avatar
28 here seems to be about right on my 35's, the tire store put in 40 when they mounted my tires and it rode terrible.
Old Nov 21, 2011 | 02:41 PM
tenmile's Avatar
26 PSI on the street, 315/75/16. 28+ starts to ride a bit too rough for our crappy roads.
