Aev black pintlers
I am looking at new wheels for my JKU. I like the style of the AEV Pintler and I am looking for input on the wheel. I want black wheels and I know AEV has the new black wheel coming out will it come in a satin black also or just the gloss black in the photo. They are a little more expensive than most of the other wheels I am looking at are they worth it?. I am going to run 35's on 17 inch rims. Any input is appreciated. Thanks 3K91
- The Pintler is "hub centric", meaning the center bore of the wheel is the same size as the hub. The weight of the tire/wheel is mostly on the hub, not just the mounting studs. There are few choices out there that are truly hub centric.
- The valve stem is protected, but it is near the outside of the wheel. This is a design flaw in my opinion (AEV doesn't agree with me). If you use the standard TPMS, you'll break them off every time you get close to a rock. After I broke off the second one, I had them banded inside the wheel and used "shorty" rubber valve stems. No more issues. Removing the TPMS and using something like the Procal might even be better.
- The center cap is cheesy and cheap (as in built, not to replace). Most are.
- Very light weight compared to some. This has the advantage of less rotational mass to get moving, and less unsprung weight. There's a ton of opinions on this, but various articles say unsprung weight is like 4:1 more (or 7:1 or 10:1 or...). To me weight was important.
- I like the look of black wheels, but the Argent is almost the same color as the aluminum itself. After a day in the rocks it's hard to tell from a distance where the scrapes are. With black I would think that the tiniest ding would be noticeable. Some seem to wear the dings as 4x4 merit badges.
Originally Posted by kb7our
Just got these and am very pleased with the look, quality, and setup!
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=260799"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=260800"/>
I have the ardent and love the colour. Then the blacks come out. I thought that I would just paint mine when the time comes. The prices for these rims are not to bad. I all so thought I should have got the bead locks but the last time being out at 8psi and my mud grapplers climbing the bumper ,not breaking the bead I don't need them
They will rub when you turn without spacers. May or may not be a big deal to you but I know when you can't use full turn on tight trails, in a parking lot or when trying to do a U turn it is a PITA.
Originally Posted by rubi3
Here's a pic showing them. I'd say they're matt black, not glossy.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=261626"/>
