Rear only body lift question
Has anyone installed a body lift to the rear end only? I have a 4 inch pro-comp lift and it seems like my back end sits just a bit lower than my front and I have been toying with the idea of lifting just the rear. Anyone try this?
Teraflex makes different size rear only spacers that can be used with or without the factory rear isolators. Thus, you can add thicker spacers to both sides (say 1" spacers) but use only the passenger side factory isolator and the end result is total lift for both sides and now leveled also (if your rear tire carrier attaches to the passenger side).
Thanks for all of the input.
