265/75r16
Old Nov 26, 2011 | 07:10 AM
MrHooah04's Avatar
Default 265/75r16
Hello all, lookin to purchase my new set of shoes today and just need a double check on the size.
I plan on buying 265/75/16 Cooper Discoverer STT's and throwing them on some soft 8 16x8's. The rims have +12mm offset and 5" BS. Will this cause any rubbing issues on my stock jeep?
V/R
Old Nov 26, 2011 | 07:28 AM
Robar's Avatar
No, it's only about a 31" tire. I had that size on my '07 for a while and had no rubbing. Your speedometer may be off a little.
Old Nov 26, 2011 | 07:43 AM
AirForceMike's Avatar
X2 That about covers it!
Old Nov 26, 2011 | 10:12 AM
MrHooah04's Avatar
Thanks robar....question real quick about backspacing on a JK...how much backspacing is too much? The cragars im looking to order have 5" and i havent seen anything in regards to too much backspacing...if that is possible that is.
Thanks
Old Nov 26, 2011 | 10:18 AM
x-0448474's Avatar
i think 3 75 is too much
Old Nov 26, 2011 | 10:19 AM
Robar's Avatar
Thanks
5" of back spacing will work fine and it will push the tire out a little. The oem wheels have 6.25" of back spacing.
Old Nov 26, 2011 | 02:49 PM
Jtrain496's Avatar
Thanks
I like 4.5 but it depends how wide your tires are. I agree 3.75 is too much. My mb72 wheels have 4" backspacing and they looked great with 285/75/16 but now that I have 35/13.5 on them they stick out a little more than I would like. Not sure if I would have rubbing with those tires on a 4.5 wheel.
Old Nov 26, 2011 | 03:01 PM
WXman's Avatar
My MB 72 wheels are 4.5" backspacing (actual measurement, not what was listed). My tires stick out just a little past my fender flares.
5" of BS with 265 width tires would put the sidewalls even with the fender flares and would look perfect in my opinion.
Old Nov 26, 2011 | 03:04 PM
armycop's Avatar
I had 285/75R16s on Cragars with 5" backpacking for a little while. They were about even with the edge of the fender flares. The 265's are a little narrower. You may want to look at the 285's it's a popular tire size so there are lots of choices.
Old Nov 27, 2011 | 09:43 AM
MrHooah04's Avatar
all great info, thanks everyone
^ So if i stepped up to a 285 would that cause any rubbing issues as far as keeping the 5" of bs?
