**Direct me which way to go for a LIFT**
need help on which way to go on lifting my 11 JK
it is a two door
here is my thing. the jeep will be more of an EXPEDITION type jeep going over small rocks, puddles, mud. the usual stuff. not looking for something to climb huge rock piles or anything
again it will be a daily driver type on the road and want something to hit the trails with also
looking at either 3.5 or 4 inch lift. max tire size would be 35s, 37s
please help me out with this and show my the links please!!
me and my buddy can do this in the drive way or on a lift since we have all the tools also
help a fellow JKer out!!
it is a two door
I subscribed...i want to know too. I have an '11 4dr and its also my daily driver. I'd also like to know the difference between a "lift" and a "leveling kit" and do ya need one to have the other...thx
Give a price range and i'm sure you'll get feedback on a buncha different lifts.
This is a descent kit for the price
http://www.northridge4x4.com/proddet...rod=TF-1251002
will give you 3in of lift, enough to run 35's
Tons of people have run this kit with no issues
I gained 4" withe the Teraflex 3" lift. You will also need control arms if you go over 2.5, so plan on rear uppers and front lowers as the minimum. You also need to replace your wheels or buy spacers. Lifting requires lengthening the sway bar links to maintain the sway bar geometry. Your stock links tuck neatly within the stock wheel. Longer links will rest squarely on the wheel or the tire or hit the frame. Look for 1.5" spacers or wheels with 4.5" of backspacing.
The $$$ start adding up quick once you go over 2.5in of lift.
Also depending on the manf, the actual amount of lift you get with a kit may be an inch or more than the advertised height. Some give you less.
