Confused Over Bumpers for 2012....Hearing Conflicing Things
Old Nov 27, 2011 | 08:09 PM
Trappistmonk's Avatar
Default Confused Over Bumpers for 2012....Hearing Conflicing Things
I have to say that I am confused about the whole situation around adding a new front and rear bumper set for a 2012 JKUR. Yes, I have called the companies and they assure me "hey no big deal". Afterall they are in the business of sales.
With that being said, I am looking for a new full lenth (or mid length at the worst) bumper for the front---non-winch. I keep reading that people add bumpers and then have to throw on lift-kits to relevel the suspension. This is exactly what I am trying to avoid. Here is what I am looking for in a bumper:
  • Full or Mid Length
  • Non-Winch
  • Under 100 Pounds
  • Works for the 2012
  • Bull Bar Attachment
  • No cutting into frame
  • No need to add new springs or spacers
I like the AEV Premium the best, but hear weight figures all over the place from 70 pounds to 116 pounds, cutting into the frame for the 2012s, and water pump relocation, and also weight issues around sag. What choices do I have out there? I have been looking at bumpers for two weeks now and my eyes are starting to bleed.
Old Nov 27, 2011 | 09:41 PM
Kozmothedog's Avatar
  • Non-Winch
  • Under 100 Pounds
get aluminum Poison Spyder front and back... zero wait... they are shorter though
Old Nov 27, 2011 | 10:06 PM
I'll check those out again, Kozmo. PS was one of the first places I check out, but will look harder at their stuff.
Old Nov 28, 2011 | 02:44 AM
sneck's Avatar
rugged ridge now has aluminum modular bumpers as well, might be worth checking out, although it's certainly midwidth at the widest
Old Nov 28, 2011 | 05:08 AM
ranjr's Avatar
The pump is a vacuum pump to help the brake booster and is located behind the front bumper. There are several kits to move this and it really isn't a big deal.
Old Nov 28, 2011 | 07:28 AM
BigMAK1's Avatar
Yep just relocate that vacuum canister (front) and as far as I know you're good to go with all the bumpers. I pulled the LoD (front and rear) off my 2011 and put them directly on my 2012 without issues (after relocating the canister).
Old Nov 28, 2011 | 07:31 AM
teamgreen666's Avatar
genright has some nice aluminum bumpers
Old Nov 28, 2011 | 08:44 AM
Dlampe's Avatar
I have an ARB and it bolts right on. It is under 100lbs. No cutting or relocating. I think it is similar to the look of the AEV. It's on my 2012 by the way. No issues.
Old Nov 28, 2011 | 10:20 AM
I like the ARB...so does the vacuum canister fir directly into the standard bumper location?
