buying superchip flashpaq
Old Nov 28, 2011 | 12:38 PM
elitecontrol's Avatar
Default buying superchip flashpaq
Hey, i found a used superchip flashpaq locally and was wondering if anyone had any advice for me when i go to check it out. i wasnt planning on taking my jeep to get (save on gas). The seller said it was returned to stock. SO it should be good to go. besides the obvious cables etc. anything other advice?
and any advice on when flashpaq is welcomed.
Old Nov 28, 2011 | 01:03 PM
Croce's Avatar
Just make sure its returned to stock and that the TPMS sensor feature has been restored
It should come with a USB cable to attach to PC to update. if not, its a pretty common one you can buy at a store, or probally already have for another device
Old Nov 28, 2011 | 01:15 PM
Is there a way to check without having it plugged in?
Old Nov 28, 2011 | 01:17 PM
Croce's Avatar
i think when you turn it on (which requires to be plugged in) it tells if its associated to another vehicle
Old Nov 28, 2011 | 01:22 PM
nthinuf's Avatar
Nope, it's a hunk of plastic with a cable until you plug it in.
You are buying from the current owner, correct? Have him plug it in to his JK so you can verify that it is not still vin locked. As noted above, the tpms is a separate function and needs to be re-enabled, in addition to the 'return to stock' to get rid of the tuning, before you take possession of it.
If you get it home and it is still locked to the previous owners vehicle, you will need to make another trip or pay the folks at superchips to unlock it.
Old Nov 28, 2011 | 03:57 PM
SergeantChuck's Avatar
I just sold mine to someone a couple weeks ago. When you first plug it in it will tell you it is associated with a vehicle and list some information. Once I restored my JK back to the stock tune I unplugged the tuner and plugged it back in. If it is not Vin locked when you plug it back in it will boot up and go straight to the screen to select type of tune.
Old Nov 29, 2011 | 08:06 PM
Ride_My_Jeep's Avatar
I am about to take the JK into the dealership and need to restore it back to stock but i disabled the TPMS....does anyone know what it has to be set to? I forgotten what setting it was on when I messed with it
any help is appreciated
