AFE Stage 2 installation, Please help me!
Old Nov 29, 2011 | 05:37 AM
Apwjk518's Avatar
Default AFE Stage 2 installation, Please help me!
Morning Jeepers, am trying to install a stage 2 on my sport, one slight issue, the OE sensor doesnt quite reach the rubber grommet on the new intake tube. No matter what i try it is not making it. If i splice the 2 wires and
extend them to reach, any issue with doing that???
I cannot reisntall the OEM version, am 95% complete and dont know what to do??
thanks!!
Old Nov 29, 2011 | 06:07 AM
mrlobaloba's Avatar
If I were you instead of splicing the wire, I would probably drill a new hole in the intake tube and put a rubber grommet filler in the old hole. Just make sure to remove all the metal shavings.
Old Nov 29, 2011 | 06:11 AM
Tonka_yellow's Avatar
X2 on drilling a new hole. Just make sure you don't drill while its in the car and clean it out good before installing.
Old Nov 29, 2011 | 06:19 AM
Apwjk518's Avatar
thanks for the reply, that wont work. Its way too short. My wire harness is too tightly embedded under the manifold. I have no choice but to cut/splice the two wires. I only need to add 3-4" tops
Old Nov 29, 2011 | 06:44 AM
Could you get a picture of what your talking about. It will make it easier to see the problem
Old Nov 29, 2011 | 09:28 AM
Apwjk518's Avatar
OK so here's what i had to do, the afe stage 2 unit i installed set the sensor too far away, the original wiring didn't allow me to mount it. I cut and spliced new wiring to extend the sensor to reach the grommet and now im all set.
No issues with the sensor being cut and re-wired, just an FYI..
Old Nov 29, 2011 | 08:56 PM
andyfc's Avatar
Just installed my AFE, flipped the metal tube end for end ( opposite to what the picture in the instructions shows). Then air temp sensor fits fine. Just my two cents
