2011 Jeep Wrangler JK RIPP Supercharger Kit NOW available
Old Dec 1, 2011 | 12:44 PM
RIPPMODS's Avatar
Sponsoring Manufacturer
Default 2011 Jeep Wrangler JK RIPP Supercharger Kit NOW available
RIPP Superchargers is proud to announce the 2011 Jeep Wrangler Supercharger kit. Producing 230 rear wheel HP and 240ft/lbs of rear wheel torque. Complete systems are fully calibrated, plug and play ready, featuring the self contained V-3 Si-Trim centrifugal supercharger with air-to-air front mounted intercooler. The complete system will boost your stock 2011 Jeep form 140 rear wheel hp to 230HP* and 240lb/ft* torque with 7-8 PSI from the V-3 supercharger at the factory redline.
http://www.youtube.com/watch?v=Htd6W2cHo-w Complete System Included:
  • Vortech V-3 Si-trim compressor with 3.60' drive pulley
  • Peak Manifold boost pressure: 7-8 psig @ redline on stock engine
  • RIPP Pre-Programmed Plug & Play Electronics with a safe, custom calibration for 91-octane fuel
  • Fuel system upgrade includes plug and play fuel injectors
  • Air inlet assembly includes: High-flow roto-molded ducting and high flow air filter
  • Silicone couplers and reducers with stainless steel clamps
  • RIPP PCV and breather hose provisions for both automatic and manual transmission applications
  • Easy to follow instructions
  • Hardware One Year warranty
Discharge components include:
  • Welded air/air charge cooler
  • Mandrel bent aluminum charge tubes for high flow and minimal weight
  • Stainless steel clamps
  • Silicone couplers
  • Quiet Race Bypass Valve Installation time is rated at 8 hours
Old Dec 1, 2011 | 04:14 PM
18usc371's Avatar
(Sorry - I posted this another 2011 RIPP thread but . . . )
RIPP -
If sometime soon, Diablo breaks the code for a 2011 tuner, will you switch to their tuner with the kit, rather than a piggyback? I want the RIPP for my 2011, but I also want a tuner too so I can, well, tune and do all the other stuff they can do. Would a future tuner not be compatible with the current 2011 RIPP SC?
Thanks!
Old Dec 5, 2011 | 08:18 PM
Andys11Rubi's Avatar
Got mine installed and working perfectly. I started a thread with pics here: https://www.jk-forum.com/forums/show...-Running-Great!
