Lift Help...Track Bar Q's
Old Dec 2, 2011 | 11:54 AM
OOC-07Rubi's Avatar
Default Lift Help...Track Bar Q's
TF 2.5 Lift and Bilstiens came with Rear Track bar only...Do I need the front TB?
ID:	244433Click image for larger version
Old Dec 2, 2011 | 11:56 AM
WCDAVE's Avatar
More than likely you will move your old backs to the front and use the new ones on the back. Pretty sure that would be in the instructions though.....
Old Dec 2, 2011 | 11:57 AM
WCDAVE's Avatar
Sorry, you are asking about track bars, I misread based on the picture only showing one set of sway bar links.
Old Dec 2, 2011 | 11:58 AM
WCDAVE's Avatar
Looks like you have a new TB tower for the front so you can use the stock one.
Old Dec 2, 2011 | 12:16 PM
OOC-07Rubi's Avatar
That thing right in front of the springs is the Rear track bar bracket (axle side). I'm wondering if i need the FRONT Track Bar bracket or not since teraflex only sells the kit like this without the front track bar extension.
Old Dec 2, 2011 | 12:28 PM
jbird416's Avatar
I have that same kit on my 2012 with shock extenders instead of replacing the shocks. You do not have to have it with that small amount of lift. It wouldn't hurt to have it either and it is on my short list of things to do next.
Old Dec 2, 2011 | 01:27 PM
TeraFlex's Avatar
Sponsoring Manufacturer
You do not need a front adjustable trackbar with that kit. Your better off adding front lower adj control arms so you can dial in your caster correctly for you alignment.
Old Dec 2, 2011 | 02:16 PM
nthinuf's Avatar
x2. Caster correction would be more important to me.
Old Dec 3, 2011 | 11:40 PM
OOC-07Rubi's Avatar
Thanks guys. LCA front will be my next thing to buy. How long can i run this with out causing any problems? Mainly DD right now.
Old Dec 4, 2011 | 04:33 AM
rexicon's Avatar
You do not need front lower control arms and it will not damage anything the way it is, drivie it and decide for yourself. Yes front lower control arms would make it better.
