Horn/headlight problem.
Old Dec 5, 2011 | 08:06 AM
JeepRubi11's Avatar
Default Horn/headlight problem.
Hey guys over the weekend I removed my stock horn and installed a used air horn from my brother inlaw. It plugged right up to the stock wiring without any modifications. It worked for a few seconds then I blew the fuse. I replaced the 10 amp fuse with a 30 amp fuse and now it works fine. However when I blow the horn my headlights and fog lights flicker ever so slightly,Is there something else I should do or is there something wrong? By the way I have a 2011 rubi unlimited.
Old Dec 5, 2011 | 02:08 PM
ronjenx's Avatar
The first thing you did wrong is replace a 10 amp fuse with a 30 amp fuse. That's asking for trouble.
Not only is the wiring inadequate for 30 amps, I'll bet the relay is marginally capably of carrying 30 amps.
Old Dec 5, 2011 | 02:26 PM
Blakspire's Avatar
Take that thirty amp fuse out. You ARE over drawing the horn circuit. You WILL have problems. Research aftermarket horn kits for options.
Old Dec 5, 2011 | 03:31 PM
JeepRubi11's Avatar
Thanks guys didn't realize that.
Old Dec 6, 2011 | 09:18 AM
Freewill's Avatar
Run a #10 wire from the battery to a relay, and from the relay to the new horn. Use the stock horn wire to trigger the relay. Put a 30 amp fuse or circuit breaker in the #10 wire as close to the battery as possible. If you arn't familiar with how to wire a relay, there should be tons of how-to write-ups on this site or elsewhere.
