PRESS RELEASE: Nemesis Industries Factory 44 Front Lower Shock Mount
Old Dec 6, 2011 | 02:56 PM
wayoflife's Avatar
JK-Forum Founder
Thumbs up PRESS RELEASE: Nemesis Industries Factory 44 Front Lower Shock Mount
Check it out everyone!! Nemesis has just release an awesome new Factory 44 Front Lower Shock Mount
Old Dec 6, 2011 | 05:55 PM
Absolute's Avatar
I like this idea, I'll add it to the short list.
Old Dec 6, 2011 | 05:57 PM
Bnizzle's Avatar
Hum will have to hear some reviews...do like the idea if mated up with Evo's rear set up....for lower and upper mounts...hum...
Old Dec 6, 2011 | 07:14 PM
BuckLisa's Avatar
Out of curiosity; isn't this the same concept that AEV does on their front shock that allegedly prevents the shock from rubbing the frame in which you criticized for putting too much stress on the shock mount?
Old Dec 6, 2011 | 07:16 PM
BuckLisa's Avatar
Well, after looking at it in depth, it appears it is a better design in that it pivots without bind.
Old Dec 7, 2011 | 06:03 AM
Nemesis Industries's Avatar
Sponsoring Manufacturer
Wink
Thanks we're psyched about it too. We've been testing this for over a year on our shop JK "Dixie"...its worked flawlessly...eliminating the binding associated with a parallel lower shock mount let our shocks work as they were intended.
Not a bad idea! A little extra BIND FREE travel never hurt anyone.
Thanks BuckLisa! We're pretty proud of how well it performs! Please let me know if you have any other questions.
Old Dec 7, 2011 | 06:50 AM
wayoflife's Avatar
JK-Forum Founder
as you have pointed out, it IS a better design.
Old Dec 7, 2011 | 07:17 AM
sneck's Avatar
Not that it will really matter to me since I have a lowly dana30, but how much extra flex does this give? its hard to guess because it looks like a totally different position than stock.
Old Dec 7, 2011 | 07:32 AM
We designed this bracket to:
1. Eliminate bind.
2. Move the shock outboard 2" to improve handling and clear the frame during extreme articulation.
3. Create a more focused stroke path throughout the full cycle.
4. Increase downward travel, our mounts move the mounting position up .5"...giving you an additional half inch of downward travel. That minimal amount of extra travel is on purpose...because we wanted to ensure that over flexing or compression risks were minimized on the widest range of shock options possible.
Old Dec 7, 2011 | 08:04 AM
Battlefrog's Avatar
Originally Posted by JKred
Will this be released as a D30 option as well?
X2.... Cause it would also be a great upgrade for us D30's
