Newbie changing from stock to taller tire size needs help with selection
Hello,
Newbie here. Im looking to get goodyear duratracs soon for my 08 JK. I live in michigan and regularly travel to Upper MI snowmobiling. Im thinking about a bigger tire, not necessarily wider but taller. I have 245/75/16 now i was thinking about 265/70/16 cause i like the look but ive been told to go with narrower tire for better snow traction. Duratracs offer a 215/85/16 which is taller and skinner i beleive. How will this work and will it look ok or will it look stupid in the wheel well. Id like a nice looking practical tire. Thanks for your help.
Hello,
Wow!! 215/85/16 is very skinny. In my opinion it would look odd on the jeep. You are talking about a tire that is only roughly 8.5 inches wide. Going to a 265/70/16 I believe it will put you up to about 11 inches on width. That should be fine in the snow. I would go with the wider choice on your ride. But then again I live in So Cal. No snow here so hopefully other people will respond to your thread with day to day driving experience in the white stuff.
I live a bit further north than you and I would say either 265/75/16 or 285/75/16. The little bit of extra width shouldn't make a noticeable difference. If you really have your heart set on skinny then get the 235/85/16. I ran them on my old chevy truck but the BFG AT.
Just searched for 20 mins, this is the only JK i could find with 235/85s...
Jeep 235/85r16
Jeep 235/85r16
Jeep 235/85r16
Jeep 235/85r16
if you google tire calculator you can select one that converts it to hieght, width, and rim size. Like this calculator...
http://www.redrock4x4.com/tireconversioncalculator.html
Jeep 235/85r16
Jeep 235/85r16
I love how it turned out!
If you plan on going off roading, the 285/75R16 will rub the fenders. If you don't want to lift the Jeep or change out the fenders, the 265/75R16 will require no modifications. I had a set on my first JK in '07.
