2012 sahara unlimited manual front driveline clearance problems?
I am about to install either a 3 teraflex basic lift or the 4 rancho lift and want to know if I am going to have clearance issues with the front driveshaft afterwards? Will I need the exhaust spacers or new driveline with the manual transmission?
You will definitely have front driveshaft issues and possibly a crossover exhaust issue. You will need to replace your front driveshaft with a smaller diameter aftermarket one and even with the new driveshaft, the driveshaft may still hit the crossover exhaust depending on lift size and shocks used.
As far as the rear driveshaft, I've read about one individual that had a problem with the rear driveshaft hitting his evap skid. He replaced the stock skid with a poison spyder evap skid to solve the problem. The poison spyder skid gave him an extra inch of clearance.
I have a 2012 JKU Rubicon with a 3.5" lift. I had to replace my front driveshaft with a Coast aftermarket one and I relocated the crossover exhaust with an aFe y-pipe. I haven't had any issues with my stock rear driveshaft hitting the stock evap skid, but I'm keeping an eye on it.
i can see where the rear shaft would be a problem if the rear axle isn't repositioned correctly with an adjustable track bar but, assume that it is, you should be okay with the stock shaft. either way, i'll let you know what i find out after i get my 4-door 2012 lifted as i was planning to run it with the stock rear shaft.
how long of a shock are you running?
Subscribed.
I have a 2012 JKU Rubi manual and am gearing up for a 3" lift as well.
I've been asking around for about a month now and the answers I've been getting are all over the place.
From what I've heard, it's either:
-TFlex Exhaust Spacers ($60)
or
-TFlex Exhaust Spacers + front drive shaft ($520)
or
-AFE Y Pipe ($290)
or even
-AFE Y Pipe + front drive shaft ($750)
So ummm...WHICH IS IT?????
or
or
-AFE Y Pipe ($290)
or even
Originally Posted by AgtSunshine
Subscribed.
or
or
-AFE Y Pipe ($290)
or even
or
or
-AFE Y Pipe ($290)
or even
