EVO Draglink Flip Kit
Getting ready to order the EVO Draglink flip kit and hoping to do the install myself. Hoping to hear from those that have done it before. How easy is it to drill out the existing hole in the steering knuckle to 7/8"? I have a new dewalt black oxide bit. Will an 18 Volt cordless drill have enough torque or do I have to use a more powerful drill?
Thanks!
Thanks!
your really not removing much material when you do this, your just drilling out the taper in the knuckle for the tapered sleeve to fit into.
I used some good synthetic 5W30 and a 1/2 Air Drill...... A flat piece of plate and a large c-clamp to press the insert into the knuckle..
A good electric drill would be my second option, but lets not forget its just widening out the existing area.
Use what you have, don't rush and try to stay as straight as possible.
Good luck and have fun with it~
BR~
BR~
