Hitch mount winch
Old Dec 10, 2011 | 02:26 PM
revvinkevin's Avatar
Default Hitch mount winch
I will be adding a winch to my jeep soon, would it not be best to put hitches on the back and front of my jeep and use a hitch mount cradle? This way I could pull from whichever end that will work best. Anyone tried this?
Old Dec 10, 2011 | 02:39 PM
Doc Highway's Avatar
Have a look at the following link. A fellow Jeeper in our club had this, but we found most times it was front mounted. If he needed a tow from behind, we generally had someone else pull him out. But I can see if you were in the right spot or on your own it could be good.
ht tp://www.warn.com/truck/mounting-systems/multi_mount.shtml
BT
Old Dec 10, 2011 | 02:43 PM
That's what I was thinking we would need, we tend to do expedition type wheeling and normally travel alone. I was thinking it wouldn't be that unusual to need to pull from the rear.
Old Dec 10, 2011 | 03:05 PM
Wallsofcrete's Avatar
That's what I am going to do (one day) and you can remove it all together when you are not on the trail to keep it out of the weather.
