Steering stabilizer - what mfg is the best?
Old Dec 11, 2011 | 08:54 AM
46chevytruck's Avatar
Default Steering stabilizer - what mfg is the best?
I currently have a dual steering stabilizer from Rough Country on my '07 Unlimited. One of the bushings is bad and creating a wobble at 60 MPH (I assume it is the culprit because everything else appears tight). Can you purchase just replacement bushings - if so where? The second question is - who makes the best dual stabilizer kit out there. Should I just upgrade since I have to pull it off anyhow?
Old Dec 11, 2011 | 08:57 AM
wayoflife's Avatar
JK-Forum Founder
a bad steering stabilizer WILL NOT cause a wobble or anything else for that matter. if your suspension is dialed in, you technically don't even need one. you need to be looking elsewhere for your problem - have you checked your ball joints?
Old Dec 11, 2011 | 08:58 AM
mkjeep's Avatar
I have a single bilstein . The RC dual I had was a big hunkojunk, looked cool though.
I'd pull the whole thing off and see where your wobble is from.
edit: like eddie said.
Old Dec 11, 2011 | 08:59 AM
Doc Highway's Avatar
x2 with WOL. Look elsewhere for that wobble!
Old Dec 11, 2011 | 09:06 AM
I'll keep looking. Everythnig did seem tight but I will take a crow bar to it and see if I can get anything else to move where it should not. Either way, i do know for sure that the stabilizer bushing is bad. Its a start.....
Old Dec 11, 2011 | 09:12 AM
wayoflife's Avatar
JK-Forum Founder
as mkjeep said, i'd pull the whole thing off and start looking from there.
Old Dec 11, 2011 | 09:17 AM
grizzlycountry's Avatar
Default Steering Stabilizer
X3 with WOL. I have a single Bilstein 5100 Steering Stabilizer. I think it is better than the stock stabilizer.
Old Dec 11, 2011 | 09:39 AM
JPop's Avatar
Yeah I would get the stabilizer out of the way to make it easier to figure out where your issue stems from.
