Dynomax Rockcrawler w/ Resonator?
I installed the Dynomax Rockcrawler exhaust on my 2011 JKU a few months back. I primarily wanted to get rid of the ugly stock muffler in the stock location and pick up a little better power and throttle response. Improvement in sound was a secondary consideration, although anything is better then the stock minivan noise I suppose. These days, I get complaints from the wife and family that the exhaust is too loud and drones. I don't want to go back to stock, so I need some ideas on how to cure this. Would a resonator help to quiet things down and eliminate drone? If so, is there one that is known to work with the Dynomax Rockcrawler setup?
Search found a couple things on resonators used with AFE and Gibson, but nothing on the Dynomax setup...
Thanks in advance for any suggestions!
There seems to be a lot of different glasspack style mufflers... any particular one to recommend here? A part number would be great.
As an alternative to running a resonator, is there a different style Dynomax muffler that I could substitute in place of the UFW SS muffler that would not create clearance or heat issues?
Thanks again!
Dynomax - Thanks for the reply, you've given me some hope!
Thanks again!
Thanks again!
In regards to another muffler perhaps the new DynoMax VT? But I haven't seen one mounted in that location yet...
http://dynomax.com/mufflers.php?muffler=vt
Originally Posted by Dynomax
I would look to an inexpensive small resonator, it is basically just another muffler in front to "slow" down and absorb more of the exhausts.
I have an e-mail into someone to see if it can be swapped out easily.
So I found out that P/N 17956 MIGHT work but it would be in the best interest to have a shop do it right.
It's tight under there.
