Does a 2.5" BB REQUIRE disco's?
Old Dec 21, 2011 | 01:18 PM
Black_JKU's Avatar
Default Does a 2.5" BB REQUIRE disco's?
Have ordered everything except disco's and wasn't really sure if I needed to buy them or not... The lift is a spacer lift.
Old Dec 21, 2011 | 01:35 PM
chknkatsu's Avatar
no lift requires disconnects. you need longer swaybar links. so if you get a 2.5 lift and you dont plan on wheeling it. you can just get longer links
Old Dec 21, 2011 | 01:49 PM
Black_JKU's Avatar
That's what I meant.... Ya know I actually think that the BB I ordered comes with them.
Old Dec 21, 2011 | 05:13 PM
81ster's Avatar
you dont need anything and you can still wheel it.
Old Dec 21, 2011 | 05:25 PM
vontox's Avatar
The stock sway bary links are really short and having just gone thru this myself with a 2"BB, I got the longer links. TF sells a set for 0-3" boosts that worked well. From what Ive read here, if you dont use them and you go wheeling, you take a chance of flipping the links and doing damage to the tie rod. If you got the TF 2.5" BB it should come with the extended links for the rear. You then reuse the rear stock links in the front.
VT
